2008-RUF-CTR
---- Specifications ----
Engine
Type turbocharged boxer
Cylinders 6
Displacement 3,746 cc / 228.6 in3
Bore 102 mm / 4.01 in
Stroke 76.4 mm / 3.01 in
Output 515 kW (700 hp) at 7,000 rpm
Max. torque 890 Nm / 656.5 lb-ft
Compression ratio 9.2 : 1
Engine control unit Bosch Motronic with OBD-2
Turbo charger two KKK turbo chargers
Intercooler two air-air-intercoolers
Transmission
Power delivery rear wheel drive
Transmission sequential 6-speed-manual transmission,
transversal, angle drive, shift indicator in the instrument panel
Limited slip differential multi-disc locking differential
Locking value load / deceleration 40 % / 60 %
Brakes
Brake callipers front/rear 6 piston fixed light alloy callipers
Brake discs front/rear ventilated and cross drilled
ceramic composite discs
Brake disc diameter front/rear 380 mm / 15 in / 380 mm / 15 in
Anti-lock braking system Bosch ABS 8.0
Wheels and tyres
Wheels front/rear 8.5 x 19 / 12.5 x 20
Tyres front/ rear 255/35 ZR 19 / 335/30 ZR 20
Performance
Top speed 375 kph / 235 mph
0-100 kph / 0 62 mph 3.2 sec
Price
Euro 380,000.00 (plus VAT)
此篇文章于 07-04-13 13:25 被 steffenzhang 编辑。
