显示结果从 1 到 6 共计 6 条
    高级会员 幼儿园小班 yaya000 的头像
    预设 帮我选一下成人奶粉
    有个问题,想问一下有经验的亲们,或是妈妈们。但也不知道是否因该把帖放这里。。。
    回国的时候想带些这里的奶粉回去,但牌子不算少,品种也好多哦,分不清。所以想问一下,如果是想给老人们带奶粉的话,因该买什么品种呀?有哪些牌子可以推荐一下。我只知道有分成1,2,3,folgemilch的等级。但最多也只了解是分别给不同的婴儿年龄吃的。那给老人就一定是要那种给最大孩子的吗?不同的含有什么效果,或是成分呀? 有没有成人奶粉啊。。。
    现在脑子混乱,那就麻烦大家和我分享一下亲们的"奶粉经验",或是给我推荐个什么具体的品种吧。
    谢谢唷
    http://www.bkanal.ch/blog/uploads/norahjones_blueberrynights.jpg
    ... sometimes, even if you have the right key, the door won't always open...
    高级会员 幼儿园小班
    预设 回复: 帮我选一下成人奶粉
    我以前问过这里的售货员,他们说没有给大人的用的奶粉,我这样问他们还觉得很奇怪。
    预设 回复: 帮我选一下成人奶粉
    囧,你拿BB的奶粉给你奶奶吃?
    这边根本没有成人奶粉,还不如让你奶奶在国内喝多点鲜奶呢!
    预设 回复: 帮我选一下成人奶粉
    引用 作者: Ada 查看文章
    囧,你拿BB的奶粉给你奶奶吃?
    正因为国内的奶粉早已不新鲜了,怎么能让奶奶和有毒的牛奶,所以才要买这里的奶粉啊。对国内牛奶的质量彻底没信任了。
    初级会员 新生儿
    预设 回复: 帮我选一下成人奶粉
    There Cheap wow gold buy wow power leveling aion wedding dresses wow power leveling is no right or wrong answer here. Some players focus on what is useful for themselves, while others focus on what will earn them the most in the auction house, still others focus on what is needed by the guild. aion gold In the end the best bet is to pick the one that suits your play style. If you are always making and selling items pick the one that sells in the auction house on your server. If you know you are rarely going to raid pick the one that suits your class best as you are not likely to get epic set items, so this will generate some of the best items you can get.wow gold In your skills section, there will be a leatherworking icon, click it to bring up your list of patterns. If you have the required ingredients a number will show up beside the pattern, this is how many you can make of that item. I find it easiest if you put the icon on a hot bar.The primary ingredient in almost all leatherworking patterns wedding dresses is some type of leather or hide and thread. In addition some patterns use items such as: pearls, gems, scales, pieces of elements and much more. Some patterns also use ingredients made from other tradeskills such as iron buckles from blacksmiths, potions from alchemists, and cloth from tailors. You can only make those items which you have the patterns for. You are given louis vuitton handbags some basic ones when you first start, but for the rest they have to be found on mobs, or buy from NPCs or other players. Some of the best patterns are only found as rare drops from high level instance dungeons. Also you can only use the patterns that you have the required level of skill in leatherworking for.From easiest to hardest the color are gray, green, yellow, orange and red.
    wedding dresses Patterns that are red will never be in your list of patterns, cxyjsdghsjdg but they are visible at the leatherworking trainers. Orange patterns will always increase your skill, yellow patterns sometimes increase your skill, green patterns will rarely increase your skill, and gray patterns will never increase your skill. cxy
    预设 回复: 帮我选一下成人奶粉
    引用 作者: qiuqiu320 查看文章
    这楼是。。。??? o.O看糊涂了
