★护肤彩妆推荐榜,睫毛夹和眉毛产品评选结果出炉 ★
:76:在别的网站上看到的~是mm们选出的最推荐,最中意的各种护肤彩妆产品~:76:
:66:供大家以后败家作参考。让每位mm都能选出最合适自己的化妆品,少走弯路。:66:
http://bbsimg.qq.com/2005/07/04/001/455.gif
http://media5.coolapple.com/images/smilies/cn07.gif评比结果http://media5.coolapple.com/images/smilies/cn07.gif:
♥睫毛夹♥:
NO.1 shu uemura的EYELASH CURLER
NO.2 Shiseido
NO.3 SANA 莎娜的39mm EX 3D驚異立體睫毛夾
♥眉毛用品♥:
NO.1 benefit的brow zings
NO.2 anna sui的魔幻霓彩眉粉
NO.3 mac的brow set
♥眼线♥:
NO.1 bb的long-wear gel eyeliner
NO.2 mac的fluidline
NO.3 dior的eyeliner pencils
♥睫毛膏♥:
NO.1 lancome的mascara
NO.2 ysl的Mascara Volume Infini Curl
NO.3 anna sui的mascara
♥眼部打底♥:
NO.1 ysl的Touche Eclat Radiant Touch
NO.2 benefit的Lemon Aid
NO.3 UD的Eyeshadow Primer Potion
♥眼影♥:
NO.1 MAC的eye shadow
NO.2 dior的Five-Colour Eye Shadow Compact
NO.3 Shu的Pressed Eye Shadow
♥散粉♥:
NO.1 Guerlain的Meteorites Powder Collection
NO.2 anna sui的魔幻映彩持久蜜粉(蔷薇散粉)
NO.3 laura mercier的Loose Setting Powder
♥阴影粉♥:
NO.1 MAC的powder:bronzing
NO.2 Armani的Sheer bronzer
NO.3 Stila的stila sun
♥腮红♥:
NO.1 benefit的benetint和dandelion
NO.2 mac的powder blush
NO.3 nars的blush
♥高光产品♥:
NO.1 benefit的high beam
NO.2 ysl的 Touche Eclat Radiant Touch
NO.3 BB的gold shimmer brick compact
♥眼部遮瑕♥:
NO.1 YSL的Touche Eclat Radiant Touch
NO.2 benefit的boi-ing
NO.3 dior的skinflash
♥脸部遮瑕♥:
NO.1 bobbi brown的Blemish Cover Stick
NO.2 Laura mercier的 Secret Camouflage
NO.3 el的Double Wear Stay-in-Place Concealer SPF10
♥隔离霜♥:
NO.1 YSL的Complexion Enhancer
NO.2 shu家的NEW UV UNDER BASE SPF 10
NO.3 chanel的ILLUMINATING MAKEUP BASE和美白base
♥粉底♥:
NO.1 chanel
NO.2 Laura mercier
NO.3 Dior
♥美白面膜♥:
NO.1 雪肌精的草本按摩敷面膜
NO.2 宠爱之名的亮白淨化面膜
NO.3 Olay的美容焕采面膜
♥去痘产品♥:
NO.1精油品牌的tea tree essential oil
NO.2 aloe vera gel
NO.3 origins的Spot Remover®Anti-blemish treatment gel
♥补水面膜♥:
NO.1 玫瑰胶,芦荟胶配合花水
NO.2 SKII的facial treatment mask
NO.3 Avene的 Masque apaisant hydratant
♥眼膜♥:
NO.1 Lifecella的美容液
NO.2 Shiseido的Benefiance Pure Retinol Instant Treatment Eye Mask
NO.3 Estee Lauder的Stress Relief Eye Mask
♥眼部产品♥:
NO.1 Kiehl‘s的Creamy Eye Treatment with Avocado
NO.2 Biotherm的hydra deto2x Yeux
NO.3 EL的 Advanced Night Repair Eye Recovery Complex
♥清洁面膜♥:
NO.1 Borghess的Fango Active Mud for Face and Body
NO.2 Origins的Clear Improvement
NO.3 The body shop 的Honey & Oat 3-in-1 Scrub Mask
♥面霜♥:
NO.1 Biotherm的AQUASOURCE NON STOP
NO.2 Chanel的 HYDRAMAX + MOISTURE BOOST GEL CREAM
NO.3 Nuxe的 Crème Fraîche Moisturizing Energizing Emulsion
♥去角质♥:
NO.1 YSL的Instant Pur Natural Action Exfoliator granule-free
NO.2 Origins的Modern Friction
NO.3 Sisley的Gentle Facial Buffing Cream
♥toner♥:
NO.1 花水(精油品牌)
NO.2 Clarins的Toning Lotion (Combination/Oily)
NO.3 Kiehl's的Calendula Herbal Extract Alcohol-Free Toner
♥精华♥:
NO.1 Biotherm的Pure SPA Concentrate Skin Perfector
NO.2 Estee Lauder的Advanced Night Repair Protective Recovery Complex
NO.3 SKII的Deep Whitening
卸妆产品:
♥脸部♥:
NO.1 Fancl Mild Cleansing Oil
NO.2 Shu uemura High Performance Cleansing Oil
NO.3 DHC Deep Cleansing Oil
♥眼唇♥:
NO.1 Lancome BI-FACIL Non Oily Instant Cleanser for Sensitive Eyes
NO.2 L'Oreal Dermo Expertise Gentle Eye Make-Up Remover
NO.3 Chanel GENTLE BIPHASE EYE MAKEUP REMOVER
♥洁面产品♥:
NO.1 Origins Checks and Balances
NO.2 Biotherm Biosource Enriched Cleansing Foam
NO.3 Chanel RADIANCE CLEANSING FOAM RINSE OFF
回复: ★护肤彩妆推荐榜,睫毛夹和眉毛产品评选结果出炉 ★
第一波卸妆产品,洁面产品前三名介绍
卸妆产品:
脸部:
http://www.fancl.com.cn/products/ski...ges/342581.jpg
净化卸妆油 Mild Cleansing Oil
微细份子能轻易将化妆品浮起,彻底洁净眼部、唇部和全面化妆品,不留任何化妆残渍,加水后乳化,清洗容易,且令肌肤柔滑
洁净同时去除氧化物,防止肌肤因化妆而老化变黄。
强力抗氧化,卸妆同时去除面上黄气;高度保湿,肌肤用后幼滑剔透。
使用量: 适用 (把瓶嘴按下至樽颈3次 )
使用方法: 无须湿面,将适量的卸妆液均匀涂于面上,轻轻揉擦,再用清水洗净便可。
当之无愧的冠军,卸的干净,无矿物油,不发豆,敏感皮肤和豆豆皮均可使用。
http://www.shuuemura-usa.com/images/...e_cleanser.jpg
分多种颜色,适合不同肤质使用。卸妆效果佳。但是很多人有发豆的迹象,豆豆肌肤的mm小心。
Superstar. Try this amazing cleanser and you’ll see why it’s our most popular product worldwide. Dirt, excess oil, makeup—even waterproof mascara—and other pore-cloggers dissolve easily, leaving your face a grime-free zone that is soft to the touch. Its unique water-soluble formula rinses completely, so you’ll never see a greasy residue. Olive oil, rosemary oil, and vitamin E ensure you won’t see dryness either.
眼部卸妆产品:
http://www.lancome.co.uk/img/_db/packshots/b_064033.jpg
温和,不刺激,卸的干净,连防水的妆都轻易卸掉
http://www.boots.com/images/product/1002753/ehero.jpg
价格低廉,质量上乘,性价比高
http://www.boots.com/images/product/1021015/hero.jpg
非常温和,适合敏感的眼部
洁面产品:
http://a248.e.akamai.net/www.origins...E_tall_lrg.jpg
混合偏油皮肤的最爱,调节油脂,洗完皮肤软软的,不会干,非常干净。同样适合敏感和豆豆皮
http://www.biotherm.ca/img/db/Packsh...e/L_001712.jpg
This thick foam assures a gentle cleansing for clearer and smoother skin leaving no residual film.
http://www.boots.com/images/product/1034424/hero.jpg
使用完,脸很有光泽,非常柔软,干净
第2波toner,精华前三名介绍
toner:
NO.1 花水(精油品牌)
精油品牌的花水纯露是苹果mm的最爱,专业精油品牌有jurlique,O网,Q网等。最受欢迎的花水种类是熏衣草和玫瑰。
http://uk.clarins.com/images/generic/pb/visuel/v_45.jpg
Gently completes the cleansing process.
Alcohol-free plant based lotion to refresh combination or oily skin and gently complete the perfect cleansing routine.
Beauty Benefits :
- Gently removes any traces of Cleansing Milk.
- Tones skin and clarifies complexion.
- Promotes soft, comfortable, radiant skin.
- Moisturises and softens.
- Facilitates smooth make-up application and enhances long-lasting wear.
- Enhances the action of products applied afterwards.
Ingredients :
- Aloe (Alleviates,Moisturises)
- Orris (Astringent,Softens)
- Witch hazel (Anti-free radical,Astringent,Protects)
超级适合混合皮肤的,味道很好,里面有金缕梅成份,收缩毛孔效果不错;也有芦荟成份,保湿效果也很强。适合敏感皮,温和,不刺激。
http://www.kiehls.com/img/products/254_L.jpg
Alcohol-Free
Designed to soothe problem skin
Made with Whole Flowers and Pure Extracts
Maintains the natural balance and integrity of the skin
Not tested on animals
This effective toner is formulated with select herbal extracts to gently cleanse and soothe normal to oily skin types without the use of alcohol or harsh synthetic drying agents. Our Calendula Herbal-Extract Toner may be used to soothe and improve problem areas.
适合混合皮肤的,有一定消炎,镇定去豆印的效果。适合敏感皮,温和,不刺激。
http://www.biotherm.ca/img/db/Packsh...e/L_113023.jpg
A spa-blue, silky gel texture for an incredibly soft and velvety-smooth skin. Source Therapie is a skin perfector which acts on the skin in 2 stages:
- an instant perfecting effect. After 5 seconds, skin is incredibly soft and the complexion more even.
- a long-lasting perfecting effect. After 5 days, skin is perfected, ideally moisturized, soothed and glowing with health.
补水精华,补水很好,完全不油。
http://a248.e.akamai.net/www.esteela...30_tall_po.jpg
Product Details:
Dramatically enhances skin's natural ability to repair UV and environmental damage. Visibly reduces lines and wrinkles while it protects your skin's future, by neutralising up to 90% of skin damaging free radicals. Think of it as insurance for healthier younger-looking skin today and tomorrow.
Features and Benefits:
By Day - It neutralises 90% of skin damaging free radicals generated by UV light, pollutants and oxidants before they can damage the skin. Night and Day - It delivers advanced levels of hydration with proven hyaluronic acid to boost the effectiveness of your nourisher. Clinical tests prove these levels of moisturisation increase cumulatively with continued use. Advanced Repair contains a targeted liposome delivery system. It helps repair damage you see today and helps prevent future damage.Protects against environmental damage during the day. Repairs daily damage by enhancing the skin's own natural repair rate. Existing lines and wrinkles are reduced. Skin looks and feels softer immediately. Prevents the appearance of future signs of ageing.
初步抗老化的精华,保湿也不错,修护皮肤,能使皮肤处于比较安定的状态。
SK-II Deep Whitening evens your skin tone to promote a clear, translucent glow. This light emulsion is specially formulated to help fight the appearance of age spots and freckles.
For optimal results, apply daily and follow with your preferred SK-II moisturiser.
美白精华,见效很快。
第3波面霜,去角质前三名介绍
面霜:
http://www.biotherm.ca/img/db/Packsh...e/L_002271.jpg
Oligo-Thermal Gel Intense Moisturization - Normal to Combination Skin
24 hours of non stop hydration.
The equivalent of 5,000 liters of spa water in a single jar. Its unique formula, enriched with a Hydra-Non-Stop complex, is a genuine water reservoir for the skin, which moisturizes your skin twice as long!
This gel acts like a water network to provide instant freshness as soon as it is applied. With Aquasource non stop the skin's innate capacity to retain water is boosted to provide 24 hours non stop hydration.
The fresh texture and the aquatic fragrance and the formula provide vitality, freshness and hydration that lasts all day long. As soon as the product is applied, the skin feels immediately fresh and clean!
补水gel,不油
http://um-chanel.edgesuite.net/image...SKPRE571LG.jpg
Fresh and silky blue-tinted gel cream for dehydrated skin.
Corrects dehydration at the source. Leaves the skin rehydrated*, supple, soft and velvety.
Daily skincare treatment. Apply morning and or/evening.
非常好用的补水gel,清爽,味道好
http://ec3.images-amazon.com/images/...CLZZZZZZZ_.jpg
性价比高,光滑柔软皮肤,天然品牌,不刺激皮肤
去角质:
http://a1216.g.akamai.net/f/1216/955.../19/_57359.jpg
Instant Pur cleansing products feature a beauty water with nourishing and soothing properties: Health-Giving Himalayan Blue Poppy Water. Rich in essential trace elements and vitamins, it leaves the skin relaxed, purified and delightfully replenished.
Free from abrasive particles, this honey-coloured gel is comprised of sugars and ultra-fine oils. On contact with the skin, it transforms into a light oil and then into a milk that gently removes dead skin cells and impurities during rinsing. The skin is smoother and softer; the complexion purified and brightened.
无颗粒,温和,适合敏感皮或者豆豆皮使用
http://a248.e.akamai.net/www.origins...5_wide_lrg.jpg
Sand-blasting skin with coarse, chemical crystals? How painfully passé. Here’s age-smoothing exfoliation without irritation. Skin-refining Rice Starch, cushioned in cream, rapidly removes sluggish cells, uneven patches and signs of skin damage and discolourations. Lemon Oil kick starts the process of illumination. Vitamin C mops up skin-menacing free radicals. All while Aloe keeps skin calm and comfy. There’s no ouch, extra steps or other complications. No redness or flaking follows. The before-and-afters are amazing. Signs of lines and size of pores appear to shrink. Skin looks perfectly polished, smooth and luminous. And the perk-me-up aromas of Bergamot and Peppermint help you look on the bright side.
光泽皮肤的去角质,每次用完会白一点
http://www.sisley-cosmetics.com/imag..._1238009_l.jpg
A scrub cream which works gently to lift impurities from the surface of the skin.
Gentle Facial Buffing Cream is applied like a mask, then removed with gentle exfoliating movements, taking with it the surface dead cells and impurities which dull the radiance of the complexion.
Its very gentle formula contains Camomile, which has soothing and softening properties.
With regular use, it helps refine skin texture and maintain a smooth, youthful appearance.
By removing excess dead cells and impurities off the skin, Gentle Facial Buffing Cream enhances its receptiveness to subsequent skin care products.
温和好用
眼部产品:
http://www.kiehls.com/img/products/258_L.jpg
Unique, concentrated texture
Does not migrate into eyes
Gently moisturizes the delicate eye area
Ophthalmologist and Dermatologist-Tested
This creamy preparation with Avocado Oil, gently moisturizes the delicate eye area. Our unique, concentrated texture does not migrate into your eyes. Ophthalmologist-Tested. Dermatologist-Tested
纯粹的补水眼霜,补水保湿效果非常好
Anti-puffiness & Dark Circles
Moisturizing Detoxifying Gel oxygenation booster
A breath of fresh air that gently stimulates skin around the eyes! Especially conceived with Oxydetox detoxifying and oxygenating complex to enhance oxygenation in this sensitive area of the face. Stimulates microcirculation, reduces under-eye bags and smoothes fine lines caused by skin dehydration. This formula also includes caffeine and ginkgo biloba in combination with Pure Extract of Thermal Plankton for maximum effectiveness and optimum skin tolerance.
去浮肿和黑眼圈,算是很清爽的
http://a248.e.akamai.net/www.esteela...G_short_sp.jpg
Product Details:
This lightweight eye serum-gel works instantly to help repair past damage while protecting the delicate eye area from future damage. Increases collagen production so lines and wrinkles immediately become less apparent. Reduces puffiness and diminishes darkness for a fresher, more rested appearance. Repair complex reinforces the thin skin barrier and locks in moisture to resist irritants and other external aggressors. Enhances the application of makeup by providing a smooth, even surface. Dermatologist tested.
Anti-oxidants and lipids replenish the skin's natural protectants. Proven moisture barrier strengthens the skin to resist external aggressors and prevent damage from UV exposure. Delivers advanced levels of hydration so skin looks and feels more supple. Boosts collagen to smooth fine lines and wrinkles. Natural extracts reduce puffiness and brighten dark circles. For all skintypes. Fragrance-free, Dermatologist tested.
这个是眼部精华,后面需要加一个纯补水的眼霜
这个有去浮肿,抗皱和去黑眼圈的功效
清洁面膜:
http://www.borghese.com/images/6052RT_b.jpg
hills. It energizes and nourishes skin cells on the face and body. Special absorbing action unclogs pores, eliminates dead skin cells and detoxifies impurities. Skin feels comfortably hydrated, firmer and invigorated.
What it does
Italian Mud - Provides mineral nourishment and special absorbing action which rids skin of impurities.
Acqua di Vita® "Living Water" Complex - Revitalizes skin, reducing the signs of aging.
Geranium, Lavender and Peppermint Oils - Natural botanicals that stimulate and improve skin tone.
Avocado and Sweet Almond Oils - Moisturize and soften skin.
绿泥适合偏油皮,白泥适合偏干皮和敏感皮
http://a248.e.akamai.net/www.origins...G_tall_lrg.jpg
Be free and clear.
Clear Improvement® Active charcoal mask to clear pores
When environmental pollutants, dirt and debris get under your skin, its waste-filtering system gets jammed, pores get clogged, skin looks cloudy. Nature’s complexion clean-up crew gets to the bottom of skins overcast condition and clears the way for it to act its best. Activated Charcoal acts like a magnet to draw out pore-cloggers, White China Clay absorbs environmental pollutants, Lecithin dissolves impurities. Without all that “stuff” down there, skin “breathes a sigh of relief.”
清洁程度也很不错,价格低
这个比较温和,属于低程度的深层清洁和去角质,味道很好,适合偏干皮
补水面膜,眼膜前三名介绍
补水面膜:
NO.1 玫瑰胶,芦荟胶配合花水
http://www.alexander-essentials.com/...l-rose-gel.jpg
http://www.catalog.quinessence.com/a.../hydrosols.jpg
玫瑰胶,芦荟胶敷面大法
具体用法如下:
最简单的用法:洗干净脸,在脸上拍上一层玫瑰花水。然后涂上厚厚的一层玫瑰胶。接下来,用玫瑰花水把纸膜泡开,然后把面膜敷到脸上,大概25分钟。注意:要在玫瑰胶没有干投的时候就把纸膜敷到脸上。
第二种用法,保湿效果加强:取适量的玫瑰胶加上玫瑰花水混合,用棉签均匀搅拌,如果太绸了要多加点花水。调成精华液的状态,再扔纸膜下去泡。然后也是敷20分钟左右。
最后一种,可以收缩毛孔的用法。洗脸,然后拍玫瑰花水,再花水没有干的时候就涂玫瑰胶。要涂厚一点,15分钟左右,会觉得脸开始慢慢收紧。就在收 紧的地方用手指轻轻的按摩一两分钟。最后,用微热的毛巾盖在脸上,1分钟左右(时间短一点)。然后用绵片沾花水把多余的玫瑰胶搽掉,(不要完全搽干净,留 薄薄的一层)
便宜实惠,而且可以根据自己皮肤需要选择适合的花水。
http://www.sk2.co.uk/products/img/en...ng/bigimg1.jpg
SK-II Facial Treatment Mask boosts radiance and moisture levels and can be used by all skin types throughout the year. The mask literally drenches your skin in SK-II Pitera, resulting in a fresher and more hydrated complexion.
For super dry skins that need extra care we recommend the HOT MASK. Simply heat the mask in the sachet for 10 minutes in hot water. Remove from the sachet after and apply on a cleansed face whilst you relax in the bath. The heat and steam allows for better penetration of moisture and is both soothing and relaxing.
For tired dehydrated skins that need reviving apply straight from the pack as a COLD MASK (can even be stored in the fridge!) After 10-20 minutes the skin will fresher radiant that ever before!
SK-II recommends a "Mask a Day" for 21 days to boost moisture levels as a treatment course when your skin needs special care. Thereafter use once or twice weekly to retain the benefits.
非常好用的急救面膜,价钱有点贵,但是能马上见效
http://www.guose365.net/bookpic/20051922584370861.jpg
雅漾舒活保湿面膜
瞬间解决肌肤干渴状况、舒缓新生疤痕,使肌肤柔软、光滑。无论何时何地,感觉肌肤紧绷、干燥、泛红感疲倦、日晒后,均可使用。
特性:
˙敏感肌肤出现疲惫、暗沉、红肿发炎现象的最佳护理保养品。
˙含滋养、保湿配方,能修护肌肤角质层及锁住肌肤水份。
˙瞬间解决肌肤干渴状况、舒缓新生疤痕,使肌肤柔软、光滑。无论何时何地,感觉肌肤紧绷、干燥、泛红感疲倦、日晒后,均可使用。
特别推荐:
˙肌肤感觉紧绷、干燥时。
˙肌肤泛红时。
˙肌肤疲倦、晦暗无光时。
˙日晒后护理。
使用方法:
取适量敷于脸上,停留10-15分钟、等待完全吸收,再使用雅漾舒护活泉水喷湿脸部轻轻拍干、让肌肤自然吸收。
主要适合敏感皮肤
眼膜:
NO.1 Lifecella的美容液保?裱勰�
http://www.bgo.com.tw/images/200/BGO0003810.jpg
含有大量精華液的眼膜,保持水分,是最佳的每日眼睛保養品。
便宜实惠,效果看得见
http://www.sca.shiseido.com/images/c...ts/19102_m.jpg
Developed with Shiseido exclusive Pure Liquid Retinol Delivery System, this quick, concentrated, under-eye treatment sheet masks create a "steam press" effect, visibly improving fine lines, crow's feet, and uneven texture in just 15 minutes. Ginseng Extract and Vitamin C derivative effectively improve the appearance of dark circles and dullness.
May also be used around lips for exceptional smoothing benefits.
To Use:
- Use 2-3 times a week, after cleansing and balancing skin.
- Apply masks under eyes and peel off after 15 minutes.
- Using light pressure, pat remaining emulsion into skin along under eye area.
- For daytime use, follow with sun protection.
很喜欢,妈妈皱纹变不明显了,提升效果也很好
http://a248.e.akamai.net/www.esteela...24_wide_sp.jpg
Product Details:
A revitalising, 10-minute mask treatment for the vulnerable under eye area, diminishing puffiness and signs of fatigue. A targeted concentration of anti-stress and anti-fatigue ingredients relax and refresh the skin around the eye. Helps prevent moisture loss and gives additional moisturisation to dehydrated skin. Puffiness around eyes is visibly reduced.
Contains soothing natural botanical extracts including aloe vera, cucumber and allantoin which help to relax and refresh the undereye area. Instantly rehydrates and smoothes vulnerable skin. Laboratory tests show that Stress Relief Eye Mask improves hydration of they eye area by as much as 40% immediately after use. Improved hydration can last up to 6 hours. Skin around the eye area feels refreshed and relaxed. The delicate skin in this area is instantly rehydrated and soothed. Puffiness around eyes is reduced.
Application and Usage:
Remove the pre-soaked pads from their packet. Using fingertips gently separate the two pads from the disposable divider and apply lightly under eyes as shown. Relax for 10 minutes. Lift off pads and gently pat remaining liquid into the skin.
主要以舒缓为主,对干纹比较有效
美白面膜,去痘产品前三名介绍
美白面膜:
NO.1 雪肌精的草本按摩敷面膜
http://www.bgo.com.tw/images/300/BGO0006407.jpg
按摩‧敷臉一舉二得
可以使肤质变得很透明
NO.2 宠爱之名的亮白淨化面膜
http://www.bgo.com.tw/images/300/BGO0005295.jpg
《美容大王》推薦
主要功效
◇最特別的生物纖維面膜:
由複合微生物菌群發酵產生,是自然界最微細的生物纖維,直?絻H有20奈米,是不織布面膜的133分之1,能與肌膚極度密合。具「�?離子導入」功能,使精華液置入肌膚更有效率,增加微循環。亦適合脈衝光、果酸換膚、雷射…等美容療程後,呵護肌膚專用。
◇唯一結合三大專利配方的亮白淨化、抗皺產品再度取得三大重量級專利配方Lumiskin、Melacear2、Matrixyl。
◇三種超級抗氧化物成份:
添加「植物性女性荷爾蒙」的「去醣基大豆�?黃酮素」、維他命E、西印度櫻桃萃取精華。
◇美白經典?h方成分:西印度櫻桃抽出物、甘草抽出物。
◇鎮靜肌膚預防發炎:洋甘菊精華。
很好用,但是不太容易买,需要去bgo网购
NO.3 Olay的美容焕采面膜
http://www.olay.com.cn/product-sc/ph...ax89183638.jpg
成分
复合Cinamide,可以重塑胶原蛋白
三重高浓度深层净白系统(维他命B3、维他命C和天然桑树精华)
六种植物精华(常春藤、圣约翰草、山金牛、金缕梅、七叶树、葡萄叶萃取物)
功效
重塑胶原蛋白,有效净白肤色
收细毛孔,肤质明显改善
明显淡化日晒斑,晒后修复功效明显
大量而持久补充肌肤水分
有效柔软肌肤
当时效果很惊艳,但是不持久
去痘产品:
tea tree是杀菌的王牌,非常适合痘痘皮使用,tbs的tea tree油可以直接用在脸上,精油品牌100%纯度的茶树油需要稀释。
NO.2 aloe vera gel
http://www.rosemaryshealthfoods.co.u...oepura_gel.jpg
芦荟有消炎,去红,消肿的作用,h&b的和aloe pura是比较常用的品牌,aloe pura的添加tea tree油,更是事半功倍
http://a248.e.akamai.net/www.origins..._short_lrg.jpg
Out darn spot!
Spot Remover® Anti-blemish treatment gel
You'll feel a mild tingle as blemish-busting Salicylic Acid invisibly zooms in on even the angriest blemishes to speed their banishment and reduce the look of redness, while nature's "spot-nots", Oregano and Clove Buds, help clear the look of things up. And if you've ever used a too-strong blemish treatment only to find your face flaking from forehead to chin, you'll love this speedy treatment. Unlike many blemish treatments that aggressively attack blemish with overly drying ingredients, Spot Remover® won't provoke tender skin or cause additional sensitivity.
能使痘痘快速干掉,非常见效,但是会有些刺痛
隔离霜,粉底前三名介绍
隔离霜:
http://www.neimanmarcus.com/products/mn/NMC9141_mn.jpg
A sheer highlighter that can be freely used to beautify the complexion and reveal its natural glow.
The shade range is divided into 3 families to offer multiple use:
• The "colour sheen" shades—N° 2 and N° 3—catch light on the rounded parts of the face (cheekbones, forehead, chin). Apply a few dots over your day care or make-up.
• The "colour balance" shades—N° 1 and N° 4—give the skin the perfect tonality. Apply over your day care, alone, or as a base under the foundation.
• The "colour booster" shades—N° 5 and N° 6—enhance the complexion and make a natural tan more uniform.
调节肤色很好用,但是没有spf
NO.2 NEW UV UNDER BASE SPF 10
http://www.shuuemura-usa.com/images/...952_ver_lg.jpg
A renovation of the original shu uemura award-winning, signature product: A weightless mousse makeup base that helps to even out skin tone and texture, reduce redness and minimize the appearance of pores. Use before makeup application to prepare the face for flawless makeup.
Additional benefits of new formula:
Better Spread – Increased mousse texture for even application and coverage
Better Adhesion with Foundation – Hamamelis [witch hazel] extract helps to tighten pores and make skin surface smoother
Longer Lasting – Contains Flouric Polymer Coated pigments that helps color remain true all day
Increased Protection – Increased SPF protection against harmful UV rays
很薄,很自然,能遮盖些毛孔,但是瓶口设计一般,出量不好控制
http://um.chanel.com/images/en-us/pr...MAFMU548LG.jpg
白色的能遮毛孔而且保湿。美白base有珠光,脸会被提亮,需要后面加粉底,不要单独使用。
眼部,脸部遮瑕前三名介绍
眼部遮瑕:
http://www.neimanmarcus.com/products/mn/F3C4636_mn.jpg
Instant highlighter: Touche Eclat Radiant Touch
• A take-anywhere pen-brush for adding a touch of light or banishing shadows and signs of fatigue from the eye area, the hollow of the chin, the contour of the lips and the sides of the nose.
• For all skin types.
• To use: Apply on bare skin or over make-up, then blend with the fingertips for instant radiance and freshness.
这个主要是高光作用,也能一定程度遮盖黑眼圈。有些干
http://images.amazon.com/images/P/B0...V59933287_.jpg
Say good-bye to circles and shadows around your eyes with boi-ing. Our industrial strength concealer camouflages those pesky "problems" without creasing, smudging, or wearing off. In our modest opinion, it's the world's best concealer.
Tips and tricks: Swirl your finger in boi-ing to warm the product. Apply 3 dots under your eye area where dark circles exist. Pat to blend lightly with fingertips working from the outer and inner corner toward the middle.
遮盖效果很好,但是比较干
NO.3 dior的skinflash
http://www.neimanmarcus.com/products/mn/NMC00V3_mn.jpg
比ysl保湿一些
粉底:
http://www.neimanmarcus.com/products/mn/S2C3750_mn.jpg
粉质细腻,保湿程度高,遮盖效果不错,适合遮豆豆
http://www.neimanmarcus.com/products/mn/F9C2F_mn.jpg
A revolutionary concealer that makes must-have lists everywhere, Secret Camouflage evens out skin tones and covers dark under-eye circles and blemishes. Each compact contains two shades—one to match the skin's undertones and one to match the skin's color.
遮瑕能力强,保湿。可以调配颜色
http://i.esteelauder.co.uk/images/pr...RC_tall_sp.jpg
遮盖效果不错
腮红,高光前三名介绍
腮红:
http://images.amazon.com/images/P/B0...V60921711_.jpg
Start your day the "perk-me-up" way, and keep them guessing how you look so pretty this early in the morning. Dust on our soft, pink, perk-me-up powder for instant radiance and a youthful appearance. It's the perfect shade of pink that brightens everyone's complexion without looking powdery or chalky.
Tips and tricks: Sweep the brush across the powder a few times, then tap off any excess. Brush lightly on to the apples of your cheeks in an outward motion. For the final touch, lightly brush all over your complexion.
这个更适合做散粉,做腮红不爱上色,但是很自然
http://images.amazon.com/images/P/B0...V60921724_.jpg
It's the original and still the best rose-colored cheek and lip tint. Kiss-proof and water-proof, this indelibly sheer tint gives you an innocent, yet provocative glow that will keep everyone guessing "what has she been up to?"
Tips and tricks: Draw three small stripes across the apple of your cheek. Blend in a circular motion with fingertips. Apply benetint to lips with a clean q-tip... even after your lipstick wears off you'll still have a rosy glow!
天然好气色,颜色很美。但是不容易推匀,和某些粉底不能混用,会晕开粉底。
http://i.maccosmetics.co.uk/images/p...s/M39H_128.jpg
颜色众多,便宜又大只,缺点是粉不够细
NO.3 nars的blush
http://www.narscosmetics.com/acb/sto...main_blush.jpg
颜色漂亮,持久。经典颜色是orgasm和angelika。但是喜欢裸妆的mm不太适合,里面有闪粉,有妆感。
高光:
http://images.amazon.com/images/P/B0...V62765472_.jpg
The celebrity makeup artist's secret... this satiny pink highlighter creates a young, radiant, fresh complexion on all skin tones. Use it as a spot highlighter or blend all over your complexion...the soft-focus sheen is enticing and sexy.
Tips and tricks: Using the handy brush, draw an X on the apple of each cheek. Blend with fingertips in an upward, outward motion. For an all over glow, try mixing a small amount of high beam with your moisturizer.
不错的产品,但是也是会使某些粉底晕开
很好用,打在t区和眼部,打亮却没妆感
http://a248.e.akamai.net/www.bobbibr...p/p/E43X_l.jpg
AWARD WINNER! Shimmer Brick Compact awarded "Favorite Timesaver" by "Child" magazine (September 2006). Gold given 4-B's in "US Weekly" 'Buzz-O-Meter' (September 2006).
"Anyone can wear gold as an accent. Wear it with your regular colors to make your look special," says Bobbi. The latest addition to our best-selling Shimmer Brick Compact Collection features five different shades of ultra-luxe, pearlized pigments that blend together to create a soft golden glow.
Sweep the Face Blender Brush through all five shades of Shimmer Brick Compact and dust lightly on cheekbones after Blush. Focus on applying shimmer on the top of cheekbones - where light naturally hits the face - for the most flattering look.
To add a highlight to eyes, apply an individual shade from compact on lids or lightest shade just under browbone.
经典产品,色系选择很多
散粉,阴影前三名介绍
散粉:
http://www.neimanmarcus.com/products/mn/NM-0ERK_mn.jpg
Minimize imperfections and enhance your skin's natural radiance with Guerlain Les Météorites Powders.
Meteorites Powder for the Face
• Available in two accords to enhance and brighten all complexions.
• Pink Fresh is a soft, stylish blend of pink and soft apricot shades for an instant healthy glow.
• Beige Chic is a timeless harmony of soft beige to even out the complexion.
Meteorites Finishing Powder
• A blend of light reflective/light corrective revolutionary color spheres.
• Mauve attracts light, green tones down redness, pink gives a healthy glow, gold and pearl creates highlights, and white brightens.
• Apply wherever you want a healthy glow.
很可爱的设计,能够提亮脸色,但是不方便携带,而且容易刷不匀
http://www2.babidou.com/pic/2006/1/1...7%B2%89002.jpg
能够改善皮肤暗黄的mm,更白皙,但是有些不自然
http://www.lauramercier.com/images/p...transloose.jpg
控油定妆很好,还能隐形毛孔
阴影:
http://i.maccosmetics.co.uk/images/p...s/M515_128.jpg
Create the glow of sun-kissed skin with Sheer bronzer, a soft micro-fine bronzing powder. Copper and bronze hues warm skin, creating a sculpted glow with shimmering, honey highlights. All skin types.
Soft, micro-fine texture
Shimmery, sun-kissed effect
Buildable color
application techniques
Apply with the Blush brush where light naturally hits the face–across forehead, cheekbones and temples – for a healthy, radiant complexion.
一号颜色比较浅,不会太突兀
眼部打底,眼影前三名介绍
眼部打底:
http://www.neimanmarcus.com/products/mn/NMC4636_mn.jpg
提亮很好,能够遮住上眼皮的安沉
http://www.hqhair.com/images/int_cms...emonaid_lg.jpg
for natural-looking, lively eyes
This delicate yellow cream makes eyelids look fresh & lively. The formula is soft, smooth and glides right on. Wear it solo for a quick Sunday brunch look... it's that easy.
不错,专门上眼皮的打底,但是会有些干
http://www.hqhair.com/images/int_cms...rpotion_lg.jpg
There抯 a genie in this Urban Decay bottle and she fulfills three wishes: eyeshadow that lasts, color that stays vibrant all day, and absolutely no creasing. A wave of the wand applies this nude-colored miracle cream to lids. Then brush on your favorite eye color and watch it fail to disappear?like magic!
防止集线,但是不能遮盖安沉
眼影:
NO.1 MAC的eye shadow
http://i.maccosmetics.co.uk/images/p...s/M250_128.jpg
颜色多,上色也很好,但是不如日系的颜色嫩
http://www.neimanmarcus.com/products/mn/NMC04GS_mn.jpg
Five-Colour Eye Shadow Compact named Best Powder Eye Shadow in InStyle magazine's "163 best beauty buys" (April 2006 issue, p428).
Five versatile shades that allow you to create any look you want—from soft and romantic to sultry and dramatic. The smooth texture leaves a fine finish with unbelievable staying power.
5色眼影盘,颜色配色不错,很多样
http://www.neimanmarcus.com/products/mn/NMC040C_mn.jpg
Finely-milled pressed powders in Pearl (P), Matte (M), Metallic (ME), and Iridescent (IR) shades. Applies sheer or layer for intensity. Velvety-finish. May be used as eye liner with dampened eye liner brush.
喜欢,颜色不错,上色也好
眼线,睫毛膏前三名介绍
眼线:
http://a248.e.akamai.net/www.bobbibr...p/p/E0KK_l.jpg
AWARD WINNER! Voted 'Best Long-Wearing Shadow or Liner' by "In Style" Magazine (April 2006). This innovative eyeliner offers the precision of liquid liner and the ease of a gel-based formula. Color is long-wearing and water-resistant. Can be used to create subtle to dramatic looks. Best-selling Sepia Ink featured in Bobbi's NEW Violet Look.
很好上手,不错
NO.2 mac的fluidline
http://i.maccosmetics.co.uk/images/p...s/M5F3_128.jpg
Ultra-smooth, Fluidline’s gel formula provides the precision of a liquid liner with a silkier, softer finish. Goes on “foolproof” with a brush in an easy dip-and-stroke action. Long-wearing. Smudge-proof. Lines up in a rich array of colours and finishes.
不错,比bb便宜
http://www.neimanmarcus.com/products/mn/NMC00VJ_mn.jpg
A must-have, all-in-one beauty tool. These rich pencils are dual-ended with a soft pencil at one end, and a foam tip at the other for blending. Inside the cap is a sharpener for application precision, allowing you to choose between a more natural look or a smoldering eye.
没用过,很多人赞
睫毛膏:
http://www.neimanmarcus.com/products/mn/NMC054C_mn.jpg
很多姐妹赞,不错
http://www.neimanmarcus.com/products/mn/NMC02RE_mn.jpg
As seen in InStyle magazine (May 2006 issue, p384).
For unparalleled curl.
• Available in black or brown to compliment every skin tone.
• Thickens and curls lashes in a single stroke.
• Apply to perfectly dry lashes.
非常好用,我喜欢
http://www.annasuibeauty.com/site/im...ascara_1-1.gif
没用过
睫毛夹,眉部产品前三名介绍
睫毛夹:
http://www.shuuemura-usa.com/images/...548_lg_ver.gif
The exclusive design of the shu uemura eyelash curler is curved at an angle that suits all eye shapes. Its silicone rubber pad allows for the appropriate amount of pressure to curl lashes naturally. With a swipe of Basic Mascara, curled lashes remain in perfect shape all day. An InStyle Best Beauty Buy and awarded as one of Town & Country's "Top 150 Best Beauty Products".
不错
NO.2 Shiseido 27票[IMG]file:///C:/DOCUME%7E1/li/LOCALS%7E1/Temp/moz-screenshot-2.jpg[/IMG]
http://www.meiliyou.com/image/078/11534.jpg
专业化妆师首选!
资生堂优质睫毛夹!
世界上最多专业化妆师推荐的滋生堂睫毛夹!
大S"强力"推荐的产品!
可别小看睫毛夹的作用,使用廉价的产品,不但不顺手,成型后的睫毛看上去生硬,边角的幼细睫毛不能顾及,严重的话还会伤害娇嫩的睫毛和眼帘肌肤,得不偿失呢。
效果自然又卷翘,不管是幼细的边角还是中间的睫毛,全部往上翘翘翘。宝宝强力推荐啊!!(日本原装进口,夹子上有SHISEIDO的LOGO的,还附送一个替代的橡胶圈)
好用,不夹眼皮,翘
http://img.store.pchome.com.tw/%7Epr...g?p=1172842576
●超彈力彈簧裝置可使睫毛捲度更加明顯
●夾頭有39mm設計,3D超廣角讓您的睫毛捲翹有型
●夾頭膠片採用彈力超佳特殊成型設計,不傷睫毛又可以夾得更翹
没用过,很多人赞
眉部产品
http://images.amazon.com/images/P/B0...CLZZZZZZZ_.jpg
好用,一边眉胶,一边眉粉,还有附带小工具
http://www.chengdecs.com/images/52hz...mg/b102023.jpg
全新上市魔幻霓彩眉粉anna sui的化妆品洋溢着浓浓的复古气息和绚丽奢华的独特气质,华丽的装饰主义都集于她的设计之中,形成了她独特的巫女般迷幻魔力的风格。
她选择以代表强烈欲望的紫色来包装其化妆品系列,以黯紫色为主色的包装,周围布满了红艳的蔷薇,像极了70年代妩媚的面粉盒;复古俏丽的化妆品系列让mm们爱不释手。
口碑不错
NO.3 mac的brow set
http://i.maccosmetics.co.uk/images/p...s/M39E_128.jpg
染眉胶,很好用
iemma
看来我用的都"傍上有名"啊...哈哈.....
看来mm是高手~~~:20:
水冰橙
宝贝,俺给你置顶了阿。。这帖不错的说:74:
:79::79::79::79::79::79:
宝贝真好~~~:74::74::74::74::74:
仁仁
害我又有去败东西的冲动了
我也是。。。。。
坏事了。。。。
周六和宝贝去看。。。。。
眼线:
买这个还要买刷子。。。。加一起就要50欧。。。。
眼线:
很多姐妹赞,不错
眼影:
NO.1 MAC的eye shadow
散粉:
这几个俺都有,吼吼吼~~~:20::20:
那个兰寇的睫毛膏很赞,以前一直用ysl的,后来遇到了这个,就喜新厌旧了:20:拉长和浓密效果都很不错,不过不太适合裸妆,刷出来有洋娃娃的感觉
娇兰的蜜粉就不用多说了,姐妹们都知道哈,个人觉得效果不错,里面微微的闪亮粒子,在脸上自然又pp
最后赞一下bb的眼线胶哦,现在的最爱,呵呵,自然而且不会晕。就是买的时候刷子有点小贵
