The iPhone 2.1 software update
The iPhone 2.1 software update contains many bug fixes and improvements. To get it, connect your iPhone to your computer using iTunes 8 and click Check for Update.
Update includes:
Decrease in call set-up failures and dropped calls
Significantly better battery life for most users
Dramatically reduced time to backup to iTunes
Improved email reliability, notably fetching email from POP and Exchange accounts
Faster installation of 3rd party applications
Fixed bugs causing hangs and crashes for users with lots of third party applications
Improved performance in text messaging
Faster loading and searching of contacts
Improved accuracy of the 3G signal strength display
Repeat alert up to two additional times for incoming text messages
Option to wipe data after ten failed passcode attempts
Genius playlist creation
回复: The iPhone 2.1 software update
来个中文版
iPhone firmware 2.1正式发布
Apple如所承诺的,今天终于发布了大家期盼已久的iphone firmware 2.1! 现已可通过iTunes升级。
这次升级包括以下更新:
- 提高通话连接成功率,减少电话掉线
- 对大多数用户,可明显延长电池时间
- 在从POP和Exchange账号获取邮件方面做出较大改善,增强了电子邮件可靠性
- 安装第三方应用程序可以更快
- 解决了由于安装程序过多造成的死机和当机问题
- 改善短消息的性能
- 加速对联系簿进行加载和搜索
- 让3G信号强弱的显示变得更准确
- 短消息提醒可以再重复最多两次
- 多了选项设定,当10次输入密码错误后,自动清除所有数据
- 建立Genius列表
